here now in all over the world business according to any smart phone is most wanted issue so there for we need to know and buy original smart phone and we are compulsory to understand how to check it's original manufacture,models,boards,screen,and etc....
so please help me how to check and know that it's original,fake,or refurbish phone.... especially need info about Samsung and apple smart phone
There are sites that you can check online showing a comparison between genuine and non-genuine specimens of a particular device. The points of difference will vary from one device to another.
Whether buying new or refurbished, I can't think of any good reason for buying from any source other than those of high repute. If you do that you should be all right.
As Belodion said, and you can also download Samsung Kies or Samsung Smart Switch and see if you can connect with usb.
First off try an app like Phone Spec, and the Antutu app has a device information page.
The original Genuine Galaxy app is no longer I think but there is an app of the same name.
You can also go to Sammobile and input the version name and region.
