1. AISSprof's Avatar
    Strange problem. I have not found it in searches. The Smart Lock Trusted Location fails because it appears the devices assumed position drifts to nearly a km away. Once I unlock it, I can see on Google maps that the center of location of a HUGE circle is several blocks away. Shouldn't it check first where I am?
    12-03-2015 09:54 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you have the GPS radio turned on (i.e., Location set to High Accuracy)? If Location is set to Battery Saving, and you're relying on the cell signal and wi-fi for location, that can be significantly less accurate.
    12-03-2015 11:42 AM
  3. AISSprof's Avatar
    Version 5.1 on Moto X PE (2015) version. Yes, mode is "high accuracy". I get a sense that it simply does not check frequently enough.
    12-03-2015 01:29 PM
  4. B. Diddy's Avatar
    That's weird, because assuming the GPS has a good signal lock, it ought to be pretty accurate. What happens if you change Location to Device Only (which only uses the GPS, and not the cell signal or wi-fi)?
    12-03-2015 05:54 PM
  5. AISSprof's Avatar
    It started just after the Google Fit developers, an app which I use, announced a change when they activate the GPS for tracking. I'll try with Device Only.
    12-03-2015 11:08 PM
  6. AISSprof's Avatar
    Fail with other location settings. I'll wait for next week when marshmallow is sent to me.
    12-04-2015 10:22 AM
  7. B. Diddy's Avatar
    Scratching my head here. Does the phone locate you precisely on Google Maps?
    12-04-2015 10:49 AM
  8. AISSprof's Avatar
    Yes, once it collects data, otherwise I'm centered a great distance away and the size of the blue error circle is many blocks wide. Yep, it is odd.
    12-04-2015 07:44 PM
  1. Transfer photos from one album to another on Note 3
    Last Post: 12-03-2015, 12:03 PM
  2. My watch is on a different language. How do I get it back to English?
    Last Post: 12-03-2015, 12:00 PM
  3. Why does my Sony Xperia Z1 Compact reboot on the uninstall of an app?
    By AC Question in forum Sony Xperia Z1 Compact
    Last Post: 12-03-2015, 09:39 AM
  4. Replies: 0
    Last Post: 12-03-2015, 09:32 AM
  5. Response to tall guy's answer.
    Last Post: 12-03-2015, 09:28 AM
