1. AC Question's Avatar
    I cracked my screen and i am wondering if it is possible to use my computer as mobile screen? sort of like remote desktop that you find in PCs
    I have not set any pin codes or passcodes, even the swipe unlock is off. the reason is my phone contract ends in 10 days and i can get a new phone with the same number, calls and data. until then i would like to use certain apps like whatsapp etc through the PC.
    12-03-2015 09:27 PM
  2. Teejai80's Avatar
    Hi and welcome to Android Central.
    You can mirror your screen, however, any solution will require some setup on the phone first.
    Just try and get a new phone early, you might get a nice person that let's you.
    12-03-2015 10:25 PM
  1. Replies: 1
    Last Post: 12-10-2015, 05:06 AM
  2. Unlocked Verizon to use AT$T, how do I ....?
    By chryssy67 in forum General Carrier Discussion
    Last Post: 12-07-2015, 01:28 PM
  3. Replies: 1
    Last Post: 12-04-2015, 07:41 AM
  4. Unlocked Verizon to be use w/ ATT
    Last Post: 12-03-2015, 09:08 PM
  5. Replies: 1
    Last Post: 12-03-2015, 08:38 PM
