1. AC Question's Avatar
    i have a Samsung E7. My storage is fulI (system memory 4.41gb, used space 11.39gb and available space 456mb) - I have no pictures,music or videoand I have moved all the app I could to the SD card (16gb). What can I do ??
    12-04-2015 12:56 AM
  2. the tall guy's Avatar
    Hi, what other items do you have on the phone that aren't on the SD card? you could try performing a factory reset to start fresh. If you have everything on your SD card then you won't need to worry about backing everything up.
    12-04-2015 03:42 AM
  1. Why won't my dynamic II cut on past the LG screen?
    By AC Question in forum LG Android Phones
    Last Post: 12-04-2015, 12:52 PM
  2. Hancom Office 2014 on my Galaxy Note 4.
    Last Post: 12-04-2015, 12:51 PM
  3. What is error code -18?
    Last Post: 12-04-2015, 06:50 AM
  4. why can't I answer another call without hanging on the other call
    By vdailey06@gmail.com in forum Ask a Question
    Last Post: 12-04-2015, 03:43 AM
  5. Moving Amazon Prime movies from Internal Tablet storage to micro SD card?
    Last Post: 12-04-2015, 12:53 AM
