A AC Question Dec 4, 2015 #1 My phone turned off on it's own and will not turn back on. I tried holding the power and volume buttons at the same time and nothing.
Javier P Ambassador Feb 21, 2014 19,480 3 0 Visit site Dec 4, 2015 #2 Which phone do you have? Can you remove the battery? Have you already tried holding the Power button for about 20 seconds? What happens if you plug the phone to the charger?
