1. AC Question's Avatar
    My phone turned off on it's own and will not turn back on. I tried holding the power and volume buttons at the same time and nothing.
    12-04-2015 10:20 AM
  2. Javier P's Avatar
    Which phone do you have? Can you remove the battery? Have you already tried holding the Power button for about 20 seconds? What happens if you plug the phone to the charger?
    12-04-2015 10:23 AM
  1. Anyone Using Google Now Launcher On Note 5???
    By garak0410 in forum Samsung Galaxy Note 5
    Last Post: 12-05-2015, 09:44 AM
  2. How can I disable apps on my Nexus 5 with Android 6.0 without rooting?
    By pipol123 in forum General Help and How To
    Last Post: 12-04-2015, 03:50 PM
  3. How can I rename pdf files in the Galaxy S2 Tablet?
    By AC Question in forum Samsung Galaxy Tab 2
    Last Post: 12-04-2015, 11:09 AM
  4. Replies: 1
    Last Post: 12-04-2015, 11:04 AM
