If you don't have one, consider buying one and inserting it. You'll need one unless you intend to use the phone wifi-only.
If you have one in the phone, try removing and replacing. The SIM or the SIM reader may be faulty or dirty. If no difference, ask your carrier for a replacement SIM.
