Samsung Stratosphere 2; music player custom equalizer not working
DerkaJeeHad
I own a samsung stratosphere 2, I want to be able to use the built-in equalizer that came with the Music Player. Everytime I choose "Custom" under the SoundAlive options which enable different sound options such as Bass Boost, or Treble boost. There is the "Custom" option that allows you to customize the equalizer to make it sound to your liking. EVERYTIME i choose it, it fails to enable the "Custom" option but every other option works fine. I CANNOT customize my own equalizer. And my music sounds like crap when played through speaks without the equalizer.... Much help needed, thanks.
FarajWala800
