1. AC Question's Avatar
    i have google on hub with tp link and want the best modem that is compatible
    12-05-2015 12:38 PM
  2. hallux's Avatar
    Cable or dsl? What provider? Not sure one modem will be "more compatible" with the router than another, I'd be more concerned with making sure it's compatible with your provider and the level of service you have with them.
    I have 30mbps service with Time Warner and have been happy with my Motorola SB6141.
    12-05-2015 08:59 PM
  1. Replies: 1
    Last Post: 12-10-2015, 01:29 PM
  2. Replies: 4
    Last Post: 12-07-2015, 12:57 PM
  3. Why screen of my LG G 2 stop knock on?
    Last Post: 12-05-2015, 05:46 PM
  4. Replies: 1
    Last Post: 12-05-2015, 12:31 PM
  5. Why is the "clear data" grayed out for settings on my lg g3?
    Last Post: 12-05-2015, 11:46 AM
