1. RJ Mc's Avatar
    Like said, I'm using a USB-C to HDMI MHL adapter to output my phones sound to my yamaha receiver, as I want to listen to DTS tracks on my home stereo. The receiver sees the signal and my phone, using MX Player, is properly playing the DTS tracks, but for some reason the receiver is only receiving a stereo signal, so its only giving me 2.0 sound. I can't for the life of me figure out what step I'm missing. I even went so far as to install Dolby Atmos on android but that was a no go too. Any ideas?
    12-06-2015 12:30 AM
  2. Nathan Laing's Avatar
    I'm having the same issue. I've verified I have MHL outputting in surround in the settings. Did you ever get this figured out?
    09-04-2016 06:53 AM
  3. Mooncatt's Avatar
    I'm not very experienced with this, but I remember an update a while back to MX Player that removed some of the Dolby codecs due to licencing issues. So maybe it's MX that's simply not outputting a 5.1 signal?
    09-04-2016 09:49 AM
  4. RJ Mc's Avatar
    Nope, never got it working. I ended up talking to both Yamaha and LeTV support to figure out why. Apparently, though the Max and the chip manufacturer "claim" to support it, in actuality, the Max software does not. Rather, it proprietarily included in only one of their music apps, I forgot which one, its like LeTV Music or something like that. In that app, you can download and listen to music, and SOME of those songs will support surround sound audio, and that's the only time it will kick in. Otherwise, it'll always output mono/stereo. So for this phone, it's not going to happen. I consider this a form of false advertising personally and am a bit steamed about it.
    09-04-2016 11:20 PM
  1. Replies: 1
    Last Post: 12-15-2015, 09:42 AM
  2. Emails coming on Samsung S6 but not on my pc - same account
    Last Post: 12-06-2015, 12:27 AM
  3. Ink spill on galaxy s6 not sure what to do
    By Wolfess in forum Ask a Question
    Last Post: 12-05-2015, 11:50 PM
  4. Replies: 1
    Last Post: 12-05-2015, 10:20 PM
  5. Replies: 0
    Last Post: 12-05-2015, 09:20 PM
