Hello, first off I hope I'm asking this in the correct section. I switched over from an iPhone 6 plus on ATT to the Nexus 5x on Project Fi so I'm not quite fluent with Android.
On to my question. Well i was just messing around in the settings and when looking at my data usage I noticed "Android OS" by itself has managed to use 130mb of Data in just 4 days. And when I check it says it used it in "Background".
Anyone know what this is? I don't want to end up with my data drained within a couple weeks while not even using the phone.
Thank you!
Thank you!
