1. AC Question's Avatar
    OK - I give up. Is it possible to increase the volume of the notification sound for incoming text messages, or only choose between them?
    I get maybe 5 messages per day, and they're almost always important, so I want to hear them. The choices of the various whispers and gentle coughs I am offered are such that I can only ever hear an incoming text when my phone vibrates on a hard surface - I have NEVER heard the text notification sound. That is just plain ridiculous. Help?!
    12-08-2015 02:57 AM
  2. dumpedduce's Avatar
    Welcome to Android Central.
    Have you verified that you are turning up the notification volume and not just the ringtone volume?
    Do you see a gear icon next to the slider when using the side rocker buttons to turn the ringer volume up? If so tap that gear icon and you should get several more slider options for ringer, notifications, system, and media.
    If not, check on your sound setting options.
  3. AlphaTango414's Avatar
    12-08-2015 05:35 AM
  4. elizabeth graham's Avatar
    I've got all turned up all the way
    12-06-2016 06:35 PM
  5. JenkinsEar's Avatar
    So was this ever resolved? I have the same problem here on Pixel 3, exactly 2 years later. I miss all my text arrivals due to low volume of notification. Other notifications are at a usable level. And yes, I have done all the recommended stuff above.
    12-05-2018 07:59 AM
  6. B. Diddy's Avatar
    Are all of these notifications using the exact same tone?
    12-05-2018 10:32 AM
  7. ManiacJoe's Avatar
    If you are using a user-created notification sound, you can edit the sound file to have a higher volume level.
    12-05-2018 03:42 PM
  8. Rukbat's Avatar
    Or an internal sound, if the phone is rooted.
    12-05-2018 04:01 PM
  1. My wifi is not working ,,, How do I make my WI FI Mac Address available?
    Last Post: 12-08-2015, 02:43 PM
  2. Replies: 2
    Last Post: 12-08-2015, 01:32 PM
  3. How do I fix the authentication error on my Samsung Galaxy Tablet 2?
    By AC Question in forum Samsung Galaxy Tab 2
    Last Post: 12-08-2015, 08:56 AM
  4. Replies: 2
    Last Post: 12-08-2015, 05:30 AM
  5. How do I answer my Motorola Moto 3rd gen?
    By AC Question in forum Moto G (2015)
    Last Post: 12-08-2015, 05:24 AM
