A
AC Question
how can i even-out the sensitivity of the touch screen.
different apps may have different sensitivities, sometime a light tap will do, while other times multiple strong taps are required. occasionally, even then, i have to restart system to get things to work again.
i would appreciate hearing from any one with an opinion about this or, if possible, a solution.
thanks.
leonard gorsky
thanks.
leonard gorsky
