1. AC Question's Avatar
    I have a kiosk setup. It runs on android TV box with WIFI connection (no static IP). It has a "Nice Simple Photo Widget" app which plays photos from a certain SD card folder.
    I update the folder images (add/delete) from a remote PC using mobizen.
    I am using "AutoStart" app to start mobizen on boot.
    Everything was fine. I never had to visit the kiosk in last one month after the whole setup was done. But, I am at risk. Since, mobizen shows in-app purchase, they can start advertising on my kiosk without my notice not even knowing what they are doing.
    So, I need your suggestion on if there are any other ways to do this? Is there any work around to share a folder on android SD card?
    Thanks.
    12-08-2015 11:11 PM
  2. Teejai80's Avatar
    Hi and welcome to Android Central.
    Sounds like a cool setup. What about a simple drive or cloud style app. Have it to auto sync the folder, then just upload from whatever device you like.
    I think Es file Explorer has some network sharing options too.
    12-09-2015 05:52 AM
  1. Replies: 14
    Last Post: 07-21-2016, 09:12 AM
  2. s6 edge/ WIFI speed problems
    By jm5150jm in forum Samsung Galaxy S6 edge
    Last Post: 12-10-2015, 05:24 PM
  3. Forcing WiFi calls
    By kmcochran in forum General Carrier Discussion
    Last Post: 12-10-2015, 10:01 AM
  4. Replies: 1
    Last Post: 12-09-2015, 05:53 AM
  5. How can I set the stock Internet browser to save downloads to your SD card?
    Last Post: 12-08-2015, 10:30 PM
