1. AC Question's Avatar
    I'm trying to figure out what network uses least battery when I'm home. 2g, 3g or 4g. Is it possible to measure this in mA in average per hour? Thanks!
    12-09-2015 01:09 AM
  2. Teejai80's Avatar
    Not really because you will have so many variations. If you just leave it on one network you can measure the drain with a good battery monitor like gsam. However, the variation between tests would be so great that your data would be null void.
    12-09-2015 05:46 AM
  1. Galaxy Note 5, lock screen has lock at bottom, how do I get rid of it?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 03-01-2016, 10:32 PM
  2. Replies: 2
    Last Post: 01-16-2016, 04:24 PM
  3. Where is the clipboard on the Lenovo A536?
    Last Post: 12-10-2015, 01:58 AM
  4. Replies: 1
    Last Post: 12-09-2015, 04:45 AM
  5. Like to see agenda on home page
    Last Post: 12-09-2015, 02:48 AM
