1. Patrick Deschamps's Avatar
    Hello team,
    Here is my situation:
    HTC One M8 (not rooted) with Android 5.0.1 and HTC Sense 6.0
    I try to forget a wifi by long pressing it and select "forget".
    It works momentarily. A few minutes later, the wifi is back and keep trying to reconnect.
    I go deeper in the settings, to "Saved networks" and I erase ALL the saved wifi networks.
    When I reset the phone, they are all back.
    I also tried as follow:
    I checked in my Google Dashboard for all my Android devices:
    There are two actives tablet/phones: the HTC One M8 and the Samsung Galaxy TAB A.
    There is the Sony Android TV, and there are two deactivated phones: my old Galaxy SII that is dead brick and an unknown device (which I probably accessed somewhere but never used again and can't delete it from the list).
    So I tried to disable the Google Backup on the M8, TAB A and the Sony TV (which does not have any option related to this but just in case you ask me) and erase all saved backup on my Google Dashboard.
    Go to my M8 (backup still off), erase all wifi names, turn off wifi, turn on wifi and BAM... All wifi networks are back and trying to reconnect.
    Can someone please help?
    12-10-2015 01:16 PM
  1. How can I get Android Pay to work?
    By AC Question in forum Android Pay
    Last Post: 05-15-2016, 12:40 PM
  2. How can I get my back and menu buttons to light up?
    Last Post: 12-15-2015, 10:07 AM
  3. Can't Send/Receive MMS On Verizon Nexus 5X
    By King Kong Bundy in forum Nexus 5X
    Last Post: 12-10-2015, 09:43 PM
  4. Replies: 0
    Last Post: 12-10-2015, 12:52 PM
  5. Replies: 0
    Last Post: 12-10-2015, 12:14 PM
