I have an old Irulu AK306 tablet. I just want to tweak it and mend it. This is not my main device so there's no hurry really.
My issue is that the power button poped off, not only that, the button on the circuit board is also gone so there is no way to turn in on with a screwdriver or to do a power button+volume button combination to load up the bootloader. I was left with only two button available, up and down Volume button since there is no physical Home button. I tried to do a combination with the two button that I still have left. Not working... Now, the only screen that I can make appear is the charging battery screen.
My question is, can I power on my device (or load the bootloader) with something else than adb, fastboot commands.( My computer does not detect any android devices on battery charging screen) Maybe with a circuit, electricity trick?
I know this isn't obvious but if you tell me there is absolutely no way I'll give up
Thank you.
Thank you.
