1. robh2's Avatar
    Need a phone to replace my wifes Samsung S5 and it needs to be same size because of her running gear that she has for that size phone. Need it to be 64g internal memory and good battery life. The S6 seems to have a bad battery life so avoiding that one for now. Would love a Nexus 5X, but only has 32g of memory. Needs to be available unlocked for AT&T. Any suggestions please? Thank you.
    12-15-2015 02:10 PM
  2. sydneycooper1979's Avatar
    Hmmmmmm...........It can't have less storage if it has an sd card slot? The only things I can find are 32 gig internal memory. You could always do iPhone 6---(I know, I know).
    12-15-2015 03:40 PM
  3. robh2's Avatar
    32 internal, plus SD card would be last resort. Did you have a suggestion? Thanks.
    12-15-2015 03:45 PM
  4. robh2's Avatar
    Ugghh, this is hard. Any recommendations?
    Thank you.
    12-16-2015 07:39 PM
  5. Mooncatt's Avatar
    If you have to go with 32 GB and expandable storage, then I'd recommend looking at the G4. The screen size is larger, but the overall external dimensions may still work if the running gear has the room. It's fantastic in all areas, and has a removable battery too.
    You may be hard pressed to find your perfect phone (I know I was, and found it doesn't exist for my tastes). It seems manufactures keep increasing the phone size to fit all the features in.
    12-17-2015 02:05 AM
  6. robh2's Avatar
    Thanks Mooncatt. Yea, the size of the S5 is already at the limit of the sleeve on some of her running grear. I do like the G4 a lot on paper though.
    Any other ideas or opinions anyone please?
    Thank you.
    12-18-2015 03:04 PM
  7. robh2's Avatar
    Well I guess after over 200 people have seen this and no suggestions that fit needs, there must be no phone out there. Sad options in the android world. Sad.
    12-29-2015 05:56 PM
  1. Replies: 8
    Last Post: 12-17-2015, 09:51 AM
  2. How do I manually put Artist names in for music?
    Last Post: 12-15-2015, 01:59 PM
  3. does radio shack fix broken screen on cell phones
    Last Post: 12-15-2015, 01:53 PM
  4. Why is my phone saying sim card unknown
    By I need help in forum Ask a Question
    Last Post: 12-15-2015, 01:42 PM
