1. AC Question's Avatar
    My huawei ascend y330 keeps telling me
    Unfortunately, the process com.android.phone has stopped.
    then you'll see okay and when i click it, about five quick seconds later, it says that same thing again and i don't know what to do.
    12-16-2015 04:27 PM
  2. AlphaTango414's Avatar
    Wipe system cache via recovery mode.
    Did you happen to disable anything right before this started happening? If system cache wipe doesn't work, you may be stuck with doing a factory data reset.
    Laura Knotek likes this.
    12-16-2015 04:43 PM
  1. How can I send GIFs through text messages with my Note 5 (tmobile)?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 05-06-2016, 01:24 PM
  2. How do I know my Nexus 5 model ?
    By AC Question in forum Google Nexus 5
    Last Post: 12-17-2015, 06:23 PM
  3. Replies: 1
    Last Post: 12-16-2015, 05:22 PM
  4. Can I get free hot spot with my Sprint Note 5?
    Last Post: 12-16-2015, 05:07 PM
