hello.
i bought a galaxy gear s watch and when i did a factory reset on it it rebooted in Spanish or something similar. the model number is SM-R750. apparently they had re-flashed it... ?
anyways i went to sammobile and downloaded the firmware for me. i then used odin to flash the device. all went ok but still it shows Spanish language. i dont know why since i flashed an English firmware. should i click re-partition? i dont have a pit file though
furthermore, i even went back and downloaded the british firmware. obviously that should be english.
still, when the unit reboots it gives text in ROMANIAN.
the serial number on the device is: SM-R7500ZKAROM (where ROM is Romania).
the bastards in my country brought this unit in from romania and resold it.
so how do i fix this issue? i realize i can start the unit, go through the steps then change to english but i really want it in english.
