A AC Question Dec 19, 2015 #1 Optimus LG LS670 phone needs to be rooted and SD memory card needs to be partitioned. Help?! I have no more available space on phone.
dpham00 Moderator Team VP Moderator Apr 23, 2011 30,108 200 63 Visit site Dec 20, 2015 #2 Why do you need to root it? First I would try to do a factory data reset and only install the absolute minimum apps you need. As for the sd card, you can format it in the phone
D darksngel119 Active member Nov 11, 2015 25 0 0 Visit site Dec 20, 2015 #3 Factory reset first then http://theunlockr.com/2012/11/11/how-to-root-the-lg-optimus-s/ Posted via the Android Central App
