1. AC Question's Avatar
    my lg volt 2 Is bricked with a soft brick and I really want it to be unbricked plz help
    12-19-2015 06:22 PM
  2. sethyboy's Avatar
    If you can find the stock firmware, you can try reflashing it through the LG Flash Tool.
    12-19-2015 06:28 PM
  3. AlphaTango414's Avatar
    Download and install LG Drivers
    Download and install LG Flash Tool
    Download stock firmware.
    Place device in download mode. Power device off, while holding volume up, plug computer usb cable into your phone.
    Run the LG Flash tool .exe file
    Select “CDMA” as device type and "Diag” as phone mode.
    Use the KDZ file you previously downloaded.
    Use CSE flash option.
    Click start and choose your language in the pop up window.
    Hit ok and don't touch anything until it says 100%.
    12-19-2015 08:18 PM
  4. Ronaldxx's Avatar
    Hi, im in the same situation and i have one question, what firmware i should download? i had an lg volt 2 ls751, sorry for my bad english:^(
    06-08-2016 01:19 AM
  1. I am locked out of my lg g2
    Last Post: 12-19-2015, 08:57 PM
  2. How many wats does the nexus 6 phone wire have?
    By Lovely_Android in forum Nexus 6 Accessories
    Last Post: 12-19-2015, 05:57 PM
  3. Can I use Verizon Edge without telephone access?
    Last Post: 12-19-2015, 05:42 PM
  4. Why does my phone not turn on?
    By AC Question in forum LG L70
    Last Post: 12-19-2015, 05:31 PM
  5. Replies: 1
    Last Post: 12-19-2015, 05:07 PM
