1. Jessica Taylor4's Avatar
    Everything else works fine. I can use speaker phone and play loud music. I just can't hear anything when I make phone calls. I maxed out my call volume.
    12-19-2015 06:57 PM
  2. srkmagnus's Avatar
    Try clearing the cache of the device and see if that helps. Let us know if it does or if you have further questions.
    12-20-2015 12:02 AM
  3. Jessica Taylor4's Avatar
    I tried to reset the phone to factory setting but still no sound during calls.
    12-20-2015 10:16 AM
  4. maryedel7's Avatar
    I thought it was the audio chip so i applied pressure to it from the back of the lcd part...it worked for awhile..then i put mire pressure...worked for awhile...then i repositioned my sims to the right more and its working again
    ..so..that may be the common issue is the sims moves ever so slightly and it doesnt connect...i have a micro sims and have to use a plastic tray with it...im gonna get ahold of my carrier and see if they have just a regular sims
    04-08-2016 08:39 PM
  1. Find My Phone
    By Est_XCIV in forum Samsung Galaxy S6
    Last Post: 12-23-2015, 09:31 AM
  2. How can I retrieve photos from my busted Nexus 5?
    By AC Question in forum Google Nexus 5
    Last Post: 12-22-2015, 07:48 PM
  3. Allwinner v33 tablet with 11 gig storage
    Last Post: 12-19-2015, 10:26 PM
  4. Replies: 1
    Last Post: 12-19-2015, 08:09 PM
  5. Replies: 0
    Last Post: 12-19-2015, 06:53 PM
