1. AC Question's Avatar
    i use galaxy s duos from samsung ! i charged my battery till 100% {continuing for hours it aid 100% charging and not 100% charged like it did befor } so thiss time i kept my phone switch off and i turned it on in morning am shocked the battery percent was 10 % , if i charge the same batttery and keep it my another phone for overnight even the phn is off it shows just drain of 5-6% ! what would be the problem ??
    12-20-2015 10:58 PM
  2. belodion's Avatar
    What do your battery usage stats indicate after such a discharge, in Settings, Battery?
    Also, do you mean switched off, or fully powered off?
    Golfdriver97 likes this.
    12-20-2015 11:27 PM
  1. Replies: 3
    Last Post: 12-21-2015, 04:13 AM
  2. What phone has the best voice quality?
    Last Post: 12-20-2015, 11:52 PM
  3. Replies: 1
    Last Post: 12-20-2015, 11:48 PM
  4. Replies: 1
    Last Post: 12-20-2015, 11:46 PM
  5. Accidentally deleted weather and date on phone, how can I get it back?
    Last Post: 12-20-2015, 11:32 PM
