1. AC Question's Avatar
    and not lose my text messages and contacts? because my phone keeps having a pop up message that says google play not responding then google play stopped over and over. it is stuck in guest mode now as well
    12-23-2015 03:02 PM
  2. belodion's Avatar
    Read these guides:
    [GUIDE] SMS Backup & Restore
    http://forums.androidcentral.com/sho...d.php?t=324662
    [GUIDE] How to Factory Data Reset your Android device
    http://forums.androidcentral.com/sho...d.php?t=467262
    It may be worth trying first a Cache Partition wipe, if possible for whatever device you have. It's much easier, and causes no loss of personal data.
    Laura Knotek likes this.
    12-23-2015 04:37 PM
  1. My note 4 is completely in loop, what should I do??
    By 4384587 in forum Samsung Galaxy Note 4
    Last Post: 12-30-2015, 03:32 PM
  2. LG G4 will "save" music in Play Music but not to my music folder
    By Matthew_Moore in forum Ask a Question
    Last Post: 12-24-2015, 07:21 PM
  3. ALL phone messaging apps aren't using system time.
    By Tactic Alpha in forum Ask a Question
    Last Post: 12-23-2015, 02:47 PM
  4. Installing OS updates on non-carrier phones?
    Last Post: 12-23-2015, 02:45 PM
