1. AC Question's Avatar
    as i said, i saw i need to flash the stock rom but i cant find it, the model of my phone is verykool lotus s5001
    12-23-2015 07:40 PM
  2. belodion's Avatar
    It may be best to contact the manufacturer for advice.
    12-24-2015 06:18 PM
  3. Almeuit's Avatar
    The code is usually setup by you before you format the phone. Do you remember your code?
    12-24-2015 06:25 PM
  1. Note 5 in the new year
    By doctordwaynewilliams in forum Samsung Galaxy Note 5
    Last Post: 06-03-2016, 06:05 AM
  2. Replies: 1
    Last Post: 12-23-2015, 09:07 PM
  3. Replies: 2
    Last Post: 12-23-2015, 07:45 PM
  4. Can my Galaxy S5 16G of memory be expanded to 64G?
    Last Post: 12-23-2015, 07:33 PM
