keyboard layout file for extenal logitech bluetooth keyboard and fixing letter g.
1. external blue tooth logitech keyboard paired with lenovo a2010 on typing letter g it shows dialog complete action using with email and gmail instead typing letter g.
2. i tried to fix using adb pull system/usr/keylayout/ but not sure which one to change or modify there are many vendor...kl files existing over there.
3. How to find the vendor code for logitech k480 keyboard, i mean how to find the kl file for this keyboard.
4. what is the scan code i have to change or some solution to fix this problem.
