1. AC Question's Avatar
    The other day it was raining a lot and I had my phone on my pocket. Later, I realized that there was some water (just a little) between the case and the back side of the phone. After that, the right side of the touch screen doesn't work and the phone is acting up, opening apps when I'm writing a message or when the phone is just sitting on the table. My husband said that we can try and change the screen, but I'm not sure if it might be a hardware problem. Any ideas?
    12-28-2015 01:01 PM
  2. belodion's Avatar
    As a diagnostic, do all that you can to dry the phone, removing the back and battery if possible for whatever device you have. If matters improve, that may only be temporary, since water damage is progressive, but at least you'll have diagnosed the probable cause of the trouble.
    12-28-2015 01:29 PM
  1. What The Heck Is My Phone?
    By BCaywood in forum More Samsung Phones
    Last Post: 01-18-2016, 11:10 PM
  2. Replies: 1
    Last Post: 12-28-2015, 01:31 PM
  3. What is the feather app on the LG phone?
    By AC Question in forum LG G Flex
    Last Post: 12-28-2015, 01:06 PM
  4. Replies: 2
    Last Post: 12-28-2015, 12:09 PM
  5. How can I fix a battery drain problem?
    By Jack Marin in forum Samsung Gear S2
    Last Post: 12-28-2015, 11:53 AM
