1. seun Philips's Avatar
    my lg g3 came with 16gb but its so suprising to realise i have low memory 500mb to b precise, after using 1.2gb for apps, 103mb for pics, 1.15mb for music, 34mb for downloads, cache 20mb and misc 800mb..I av checked using diskusage and it is stating i av around 2.5gb to start with, instead of d claimed 16gb. other apps like es file manager states i av 16gb and so on, i recently copied everytin i had on my sd card, totalling 800mb ( its watmade up d misc above); into internal mem. which initially stated 4gb available space, i noticed it immediately started signalling space running out! and after this transfer, I'm left wit around 523mb available. I don't kno if this helps but avg once detected my 'device management' as malware. I eventually uninstalled using es file explorer. I'm pretty confused.
    12-28-2015 05:57 PM
  2. belodion's Avatar
    Did you buy it from a reputable source? Are you sure it's a genuine G3?
    12-29-2015 06:09 AM
  1. Replies: 1
    Last Post: 12-28-2015, 10:51 AM
  2. Replies: 3
    Last Post: 12-27-2015, 11:35 PM
  3. No USB mass storage on Samsung Galaxy Grand Prime
    Last Post: 12-27-2015, 10:39 PM
  4. On android 4.2.2 how do I set storage default
    Last Post: 12-27-2015, 08:06 PM
