Can I add VOLTE band to Xplay (1562)?
A
AC Question
can i add VOLTE band to Xplay (1562)
HI Gurus,
Firstly wish you all a very happy New year!
I am using MotoX play 1562 in India (dual sim). I am using 4g from a recently launched carrier , however i am only able to use data services and no voice services on that sim. I understand Motox play doesnot support VOLTE band in Inida( Moto g 3rd generation XT1550 does support it!)
My question is can i activate the said LTE band required for VOLTE in Xplay by any means??
Thanks
Sanjeev
samyblaze
