1. radostin04's Avatar
    Hi everyone. I would really like a battery icon or a widget which looks like the battery icon in the taskbar for Windows 7. I have been trying to find one on the google play store, but i cannot find one. If anyone knows of such thing, i will be very thankfull
    01-02-2016 03:14 PM
  2. srkmagnus's Avatar
    Hello!
    There are Windows 7 themes in the Play Store. Have you taken a look at those to see if any carry the widget you are looking for?
    Laura Knotek likes this.
    01-02-2016 04:20 PM
  3. Neroxnex's Avatar
    I'll keep my eyes open and post once I find a good one. I was looking for a similar one too a few months ago.
    01-02-2016 06:11 PM
  4. radostin04's Avatar
    Hello!
    I actually havent, i will have a look if i can find anything
    01-03-2016 09:27 AM
  5. radostin04's Avatar
    No, i actually coudnt find any themes that held this widget/icon that i want
    01-05-2016 01:46 PM
  1. Battery notification issues
    By Lou loa in forum Nexus 6P
    Last Post: 01-03-2016, 07:48 PM
  2. multi-window manually change orientation between apps
    By NicholasNavarre in forum Samsung Galaxy Note 4
    Last Post: 01-02-2016, 11:08 PM
  3. Where is the Mike on the s5
    Last Post: 01-02-2016, 02:07 PM
  4. want to put google play app on kindle
    Last Post: 01-02-2016, 01:57 PM
  5. Replies: 0
    Last Post: 01-02-2016, 01:19 PM
