I have located the 2 files that are causing all this trouble in the directory /system/app/ but i cant delete them using a file explorer (42435.apk with the package name of com.sailer.coolbrowser and its name is com.android.system and Launcher0921nwoZXla.apk with the package name of com.facebook.qdservice.rp.provider and the same name). My antivirous (malware bytes) located these two files but it couldnt delete them, i have tried multiple antivirous programs but they had no effect. This virous has modified the launcher to install the same apps containing malware everytime it boots by unpacking these 2 packages. Malware bytes has putted these 2 files in some kind of whitelist that sometimes prevent them from unpacking. And the virous has also routed so it cant be removed by a factory reset. Adware is also installed. It may seem like a mesh but any help will be appreciated . I will take any screenshots if you wish. (Android 4.1.1 on a Bitmore Tab920)
