1. AC Question's Avatar
    aghar hum positive aur middle pin ko short kar de to kia hamara phone work kare ga plz answer as soon as possible
    01-04-2016 07:34 AM
  2. RogMoore's Avatar
    Don't take any risk. you might totally mess up with your mobile.
  3. RogMoore's Avatar
    01-04-2016 07:39 AM
  1. What have you done to make the 6p easier to hold?
    By dirtyjudo in forum Nexus 6P
    Last Post: 02-03-2016, 09:39 AM
  2. Problems using american AT&T phone in the UK? have rooted but...
    By caspergotchi in forum Samsung Galaxy S6 edge
    Last Post: 01-05-2016, 03:57 PM
  3. Add-on dictionaries don't work.
    Last Post: 01-04-2016, 11:42 AM
  4. Cloud sync app? ES File Explorer not working...
    Last Post: 01-04-2016, 07:42 AM
  5. Any experience running AA on the Z2
    Last Post: 01-04-2016, 06:33 AM
