Note 5 LED Color problem
Chintan Dave
5
Hi,
I just got Note 5 before a week. After using it a while, I found that my phone LED
notification is not working for all the colours like Yellow, Pink, White.
LED notification is working fine with BLUE, RED, GREEN but not for other colours.
I set different colours one by one in WhatsApp LED notification (Setting - Notification -
LED), but not all are working and I see mixing of two colurs in case of Yellow, Pink,
White.
Any Idea why ? S6 and Note 5 both has RGB sensor but I got above issue in my Note 5 while
my friend's S6 is showing all the LED colors.
Any help would be appreciated,
Thanks,
Dave Chintan.
First of all, you have great observation, secondly it seems that the phone has manufacturing fault, as normally that doesn't happen. But the bad side is, they won't consider it as a manufacturing fault. As they might not be able to provide with the details to the service centre. Most probably they will just replace the light.
Plus do factory reset on your phone, this might help.
FahadsTech
