1. AC Question's Avatar
    I just bought a samsung J2 phone. I was able to customise a song for my ringtone but can`t find how to make my message notification sound one of my songs as well.
    There seems to be only pre selected message tones in the list and no where which says add a tone like the ringtone list did.
    Is there any way to make a song my txt notification sound or is that not possible with this phone?
    Cheers
    01-13-2016 01:43 AM
  2. the tall guy's Avatar
    Hi,
    Download a file manager, or if your phone has one pre-installed use that. Locate the ringtone that you want and cut and paste this into the notification folder. That way when you go into change the notification tone, you should see the ringtone that you moved.
    01-13-2016 02:22 AM
  1. Problem with facbook
    By Tom Bachar in forum LG G4
    Last Post: 01-15-2016, 03:24 AM
  2. Replies: 3
    Last Post: 01-13-2016, 11:08 AM
  3. Why doesn't my touch screen work anymore?
    By BenBush in forum Samsung Galaxy A5
    Last Post: 01-13-2016, 06:31 AM
  4. How do I know my Tab2 version?
    By AC Question in forum Samsung Galaxy Tab 2
    Last Post: 01-13-2016, 02:29 AM
  5. Should I get a Samsung Galaxy S6 in 2016 or wait for the S7?
    Last Post: 01-13-2016, 02:28 AM
