1. AC Question's Avatar
    i got a android tv box and it came in chinese how do i get it to be in english how do i change the language
    01-14-2016 11:53 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you can, go to the System Settings and look for the Language & Input option. If there are icons associated with menu options, it'll probably have a letter "A" icon. If there are no icons, then you may have to use Google Translate to find the correct setting. Then look for the System Language option, and change that to your preferred language.
    01-14-2016 06:18 PM
  1. How do I remove the paused shoe icon on my S5 phone?
    By kevinmcd in forum Samsung Galaxy S5
    Last Post: 01-14-2016, 05:57 PM
  2. How do I delete some files from my phone so I can get new email?
    Last Post: 01-14-2016, 01:16 PM
  3. How do I get my keyboard to appear?
    Last Post: 01-14-2016, 11:33 AM
  4. SD card problem taken from S3 Mini to S5 Mini, can I get some help?
    By AC Question in forum Samsung Galaxy S4 Mini
    Last Post: 01-14-2016, 11:31 AM
  5. Replies: 0
    Last Post: 01-14-2016, 10:57 AM
