1. rjgarnold's Avatar
    This is actually a solution rather than a question. Doing a web search, I couldn't find anything on how to copy the text of an Evernote note to S Note on my Samsung Galaxy S5, but I finally figured it out. Basically, I mistakenly deleted one of the S Notes that was backed up on my Evernote, but couldn't figure out how to get it back again. To do so, hard press on any part of the Evernote note, click the "square with dots surrounding it" icon in the upper righthand corner, which highlights all of the note; click "double pages" icon--> copies text in note to clipboard; open S Note; Go to the three vertical dots in the upper RH corner--> Insert--> Clipboard
    01-15-2016 01:41 PM
  2. SpookDroid's Avatar
    Thanks for the tip! I'm sure to many this is very helpful
    01-15-2016 03:10 PM
  1. Replies: 2
    Last Post: 01-20-2016, 05:22 PM
  2. Replies: 2
    Last Post: 01-16-2016, 12:14 PM
  3. How do you access audio on SD card?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 01-15-2016, 06:47 PM
  4. Replies: 1
    Last Post: 01-15-2016, 03:47 PM
  5. Replies: 1
    Last Post: 01-15-2016, 02:16 PM
