1. AC Question's Avatar
    so i crypted my phone..because I should add job mail , and then I was told to crypt my phone.
    it would take some time, but now it has gone over 3 hours, I was told to give the password if I should be able to use my mobile phone when I type the password then turn it off and return to the screen where I have to give a password again. when I'm not using the hpine it makes click sounds. my phone was rooted btw ..so anyone know what has happened with the phone?
    01-15-2016 02:28 PM
  2. dpham00's Avatar
    Which phone do you have?
    01-15-2016 02:33 PM
  3. dado1234's Avatar
    samsung s4
    01-15-2016 02:56 PM
  1. Why 'Set Every Other Week' Is Not Available on Android Alarm Clocks?
    By epic_user in forum General Help and How To
    Last Post: 08-25-2018, 07:39 PM
  2. Replies: 8
    Last Post: 01-17-2016, 06:17 AM
  3. Why Can't I Install Any Apps?
    By AC Question in forum Samsung Galaxy S4 Mini
    Last Post: 01-15-2016, 02:40 PM
  4. My Huawei y530 is corrupted, what can I do?
    By AC Question in forum Huawei
    Last Post: 01-15-2016, 02:38 PM
  5. Replies: 2
    Last Post: 01-15-2016, 02:12 PM
