1. AC Question's Avatar
    Hello.
    My Daughter says that sometimes her phone cannot send texts, and they get stuck until the signal returns.
    Is there an app that will log when the signal is totally lost, so that I can determine how often this happens?
    01-15-2016 04:31 PM
  2. belodion's Avatar
    Go to the stock battery usage graph and tap it to open it. Your radio signal history, among other things, since last unplugging, is revealed.
    GSam Battery Monitor also shows your signal history in the form of a graph.
    Catlog might be useful for it.
    There are probably other apps in the Play Store that would also do the job.
    01-15-2016 05:12 PM
  1. Where is my WPS pin number on my Samsung Note5?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 02-25-2017, 06:03 AM
  2. Action Memo disappears when minimized
    By yeatzee in forum Samsung Galaxy Note 4
    Last Post: 01-19-2016, 04:26 PM
  3. Replies: 1
    Last Post: 01-15-2016, 05:26 PM
  4. No more signal, question is a long shot but..
    By Joseph Brewer1 in forum Alltel Merge
    Last Post: 01-15-2016, 04:18 PM
  5. Details of music files missing when imported to phone from laptop?
    By Dooblay in forum Samsung Galaxy Note 4
    Last Post: 01-15-2016, 03:28 PM
