1. AC Question's Avatar
    So I was able to move apps before. But then I did a factory reset on my phone and now I don't have the "Move to SD card" option.
    01-15-2016 07:51 PM
  2. Rukbat's Avatar
    Some apps can be moved, some can't be. (The "move" is greyed out if the developer knows his app won't run properly from the card, and doesn't want to be bothered by people asking why it doesn't run from the card - even though the instructions clearly say it won't. For instance, widgets can't be moved.)
    01-16-2016 07:28 PM
  1. Alphabetize my MP3s on a Galaxy 3S?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 01-16-2016, 07:47 PM
  2. How to install Android 4.4.4 after rooting?
    By iditarod656 in forum Legacy Android & Other OS's
    Last Post: 01-16-2016, 07:39 PM
  3. Why can't my galaxy note 4 use wifi?
    Last Post: 01-16-2016, 07:32 PM
  4. Stopping zoodles coming on my phone?
    Last Post: 01-15-2016, 10:25 PM
  5. How to change gmail screen back into one pane from three?
    By mohair3 in forum General Help and How To
    Last Post: 01-15-2016, 07:13 PM
