1. Priyankafb's Avatar
    Dear Sir,
    How are you? My Samsung Android mobile CM(CleanMaster) antivirus tells that it has BroadAnywhere how to remove this. once I did factory reset after that it was working for few hours then again same issue started. how to fix?
    01-16-2016 10:33 AM
  2. itguyjax8430's Avatar
    Dear Sir,
    Welcome to Android Central!
    Have you tried updating the app?
    01-22-2016 09:22 AM
  3. anon(632115)'s Avatar
    I wouldn't trust anything from CM. I suggest you use a different AV. There's a few threads on here about Cheetah Mobile
    01-22-2016 09:34 AM
  1. Replies: 2
    Last Post: 09-22-2016, 12:35 AM
  2. How to partition internal memory ?
    By AC Question in forum ASUS ZenFone
    Last Post: 01-17-2016, 02:44 AM
  3. Why won't my Samsung Galaxy Tab S connect to wifi?
    By AC Question in forum Samsung Galaxy Tab S2
    Last Post: 01-16-2016, 10:56 AM
  4. Samsung s 5 mini only works on 2g
    Last Post: 01-16-2016, 10:34 AM
  5. Why does my Samsung tablet connect to wifi and not the internet?
    Last Post: 01-16-2016, 09:35 AM
