1. AC Question's Avatar
    I bought a Sony android that is also a bluray,player/Netflix , landline, etc. It did not come with a remote, I can't get it to work without it, so how do I set it up?
    01-16-2016 05:02 PM
  2. srkmagnus's Avatar
    You probably can't use it without a remote if the device does not have controls such as play, stop, fast forward, rewind, etc. You're best bet it so use a universal remote or Sony remote to configure for use on the player you have.
    Laura Knotek and Rukbat like this.
    01-16-2016 05:20 PM
  3. Rukbat's Avatar
    You can also buy a replacement remote from Sony or a Sony dealer.
    Laura Knotek likes this.
    01-16-2016 06:38 PM
  1. Replies: 4
    Last Post: 02-02-2016, 12:56 AM
  2. How do I get pics to download on my ZTE Z820?
    By AC Question in forum Other ZTE Android Phones
    Last Post: 01-16-2016, 05:28 PM
  3. Why can't I get messages from an iPhone on LG sunset?
    Last Post: 01-16-2016, 04:41 PM
  4. Replies: 1
