I found a solution, thankfully. What I did, for anyone else having this problem, was connected my SD card to my computer using an adapter and copied everything over into a new folder. Then I put the card back into the phone, went to settings, storage, and under SD card, clicked format SD card. Make sure you backed up everything on the card first! Once the SD card is cleared, connect it to your computer again and move all the aforementioned files back to the card. Once that's done, put it back into the phone and you shouldn't have a problem
. Do note, however, any apps you had previously moved to the SD card will show up as files, but will not be functional/installed even after getting them back on it. Therefore you will simply have to go to the Google Play Store, My apps, All, and find what you are missing. Any purchased apps will not need to be repurchased, just reinstalled. Now I hope that was detailed enough
. I still do not know why my SD card suddenly had an issue, maybe just a registry error or something, but this definitely fixed it, though it was very tedious... But I hope this helps anyone who is having the same problem.
