1. AC Question's Avatar
    the phone is a levono A588t . The only function that does not work is being able to use the hardware keyboard to create messages. Is there any software which I can download onto my phone or are there any good instructions which tell me how to type messaged on the hardware keyboard. cheers dimac
    01-17-2016 05:19 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    When you say hardware keyboard, are you talking about an external keyboard you are hooking up to the phone?
    01-22-2016 08:57 AM
  3. pepejoses's Avatar
    Lenovo A588t Android phone with hardware keyboard, can I get some help?-lenovo-.jpg This is the Lenovo A588t smartphone with keypad
    06-23-2016 09:10 AM
  1. What is clearmusicdownloader file on my phone?
    Last Post: 01-17-2016, 11:32 PM
  2. Replies: 1
    Last Post: 01-17-2016, 05:50 PM
  3. Replies: 1
    Last Post: 01-17-2016, 05:03 PM
