1. AC Question's Avatar
    Because my old phone had been extremely hardy, I never realized there was any harm in washing the outside of a case with water... while it's still on the phone. So I put my phone (an ASUS Zenfone 2 Laser) under the sink for probably less than 15 seconds and wiped it off. I then put in my pocket for a few minutes before trying to use it again. Because I didn't know that there was potential for water damage, I tried turning the screen on and then the phone on. After it didn't work, I realized what may have happened and I took out the battery, the SIM card, and the SD card to let them dry; however, my phone still won't turn out. Could I possibly have short-circuited my phone with so little water exposure? My phone is only a few months old, so I really hope not. Is there anything I can do?
    01-18-2016 12:52 PM
  2. sydneycooper1979's Avatar
    Hello! Yes unfortunately you could have damaged your device. Put all parts in a bag of uncooked rice and leave it for a day or two. This can draw moisture out. Good luck!
    01-18-2016 12:57 PM
  3. SactoKingsFan's Avatar
    Next time follow this guide and don't rinse off a non water resistant phone in the sink.
    http://forums.androidcentral.com/amb...e-got-wet.html
    01-18-2016 01:31 PM
  1. Why can't I have data turned on and off with Android 5.1?
    By dgman1 in forum Legacy Android & Other OS's
    Last Post: 01-26-2016, 09:59 AM
  2. why when I send a text it shows up as @@@ when received
    Last Post: 01-18-2016, 01:01 PM
  3. How do I change the email account on my Samsung S4 calendar?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 01-18-2016, 12:39 PM
  4. Why aren't text messages coming through correctly formatted?
    Last Post: 01-18-2016, 12:38 PM
  5. Why isn't the green square around all apps and phone responding?
    Last Post: 01-18-2016, 12:32 PM
