GT-I9300. Kies emergency firmware recovery code is blank, is there anything I can do?
A
AC Question
my battery perished in the phone (went all bloaty) and of course caused issues..
After trying far too many things which didn't work, I ended up trying to do an emergency firmware recovery. When it got to the bit where it displays the recovery code, the box was blank so I ended up cancelling it and trying again but the code was still blank.
Now when I plug the phone into the pc it comes up with the "firmware upgrade encountered an issue...." and suggests I use Kies - the problem is that of course there's no recovery code!
So I seem to be stuck. Is there anything I can do? Odin doesn't really seem to be recognising the phone properly, kies can't recover and I can't find any options via google.
Any suggestions appreciated.
Thanks
xx maybe me xx
4
Are you rooted? Using the australian understanding of the term, the phone certainly is! however, if you mean have it been hacked to override the normal settings = no..
Are you using the correct USB cable? define correct. If you mean the original one, I doubt it since I've had this phone since they first came out (back in 2012?).
Are you running Kies as Administrator? yes
I know I sound a bit pedantic but there's a lot of unstated knowledge assumptions there so I just want to make sure I clarify what you're looking for.
This is what I get when I try to do the firmware upgrade & initialisation and of course I can't do the recovery because there's no code upgrade-failure.jpg
anon(632115)
4,315
Thanks for clarifying things. Kies wont work on a rooted device even though it may not have a custom rom. Your only option is to track down the exact firmware for your device (sammobile) snd flash it using odin. There are many good tutorials on the net.
akbarramadhani12
