A
AC Question
Hi all,
I'm looking to buy a new, budget smartphone and I've narrowed down. My decision to the Nexus 5x or Oneplus 2.
On paper, the Oneplus 2 looks a lot better (4gb ram, etc), but I've heard that the OS and home button can be laggy at times. It is now 2016, so I'm not sure if any updates have solved this.
On the flipside is the Nexus 5x, which has less power, but seems to run very smoothly on Marshmallow, and has more regular support from Google.
So which is the better phone? Has the Oneplus 2 fixed its issues?
Thanks.
Thanks.
