Re: how do u get the sd card slot opened
If there's a little key (they usually look like an oval "handle" with a pin sticking out of one of the short curves), there should be a hole in the edge of the phone you can push that pin into and the drawer will slide out. (Do it over a table or desk - if it's the SIM slot, and you have the phone upside down, the SIM card will fall out.)
