1. AC Question's Avatar
    My infinix phone has been updating over 12 hours now without it coming up. it brought a prompt to update to 6.0, please what can I do to abort it. I have removed the battery several times but it is still the same. I cant access anything on my phone.
    01-23-2016 06:40 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    You can try booting in to recovery and doing a factory reset. Unfortunately if you do this it will reset your phone and you will lose all your data on the phone.
    Method 2- via recovery mode
    >> First turn off your infinix device
    >> Then press and hold together Volume Up + Home button + Power
    >> Then Use the Volume buttons to select “wipe data/factory reset” from the Infinix recovery screen
    >> After that, confirm the process and wait for few minutes as it would take several minutes for the Infinix device to be wiped.
    01-27-2016 09:24 AM
  1. Replies: 2
    Last Post: 04-25-2016, 05:49 PM
  2. Is there any way to go back from my backup password to my fingerprint lock?
    Last Post: 01-27-2016, 09:17 AM
  3. Help, I've got locked out of my phone, how can I get back in?
    Last Post: 01-27-2016, 09:10 AM
  4. Is there any way to download photos from your Samsung phone remotely?
    By tanniharpz in forum General Help and How To
    Last Post: 01-23-2016, 07:26 AM
  5. Why do I need to turn on sync for Google photos?
    Last Post: 01-23-2016, 06:40 AM
