1. XXMA's Avatar
    Samsung galaxy tab S pro 8.4 android 5.0.2: I have rooted it, I opened it and it worked perfectly, then auto-rebooted and when turned on my tablet says:"Unfortunately 'app name' has stopped" 'app name' were: TouchWiz Starting & other system apps and I can't use it anymore . PLEASE help me!!!!!!!!!!!!!!
    PS:I DON'T WANT TO LOOSE MY DATA (NO DATA)
    01-24-2016 04:05 AM
  2. Tech-Newb's Avatar
    Well, thats a risk you must accept when rooting your device.
    Try wiping cache partition. Turnyour tab off, hold home+power+volume up at the same time for 7 sec+-. Using the volume button to navigate, press wipe cache partition using the power button. Then reboot it. You wont lose data.
    If issues still present, make a backup then factory reset it.
    Posted with ❤Love❤
    01-24-2016 09:39 AM
  1. WiFi only tablet Cyanogenmod?
    By AC Question in forum Legacy Android & Other OS's
    Last Post: 01-29-2016, 10:26 AM
  2. Replies: 1
    Last Post: 01-24-2016, 04:08 AM
  3. Replies: 0
    Last Post: 01-24-2016, 03:44 AM
  4. Replies: 0
    Last Post: 01-24-2016, 02:32 AM
  5. How do I show more than two days history on on my hotmail account?
    By AC Question in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-24-2016, 02:14 AM
